Welcome in Tom
I take it you have a 5jj then ? Give us a bit more about your biking history so that we can get to know you bud & get some pic's up of past n present bikes as we love a good pic
to post pics . . . .
"get yourself a free photobucket account & follow the idiots guide to posting pics from your pc
posting.php?mode=reply&f=6&t=10659
or you can post direct from your not so smart phone using tapawank (tapatalk) it's great for posting pic's & notifications but wank for viewing the forum
New 4xv/5jj owners post
"Those 5jj's are a lovely bike , they share a lot of parts with the 4xv like frame, wheels & engines are similar , things that are different are ECU , bodywork i.e. tank , fairing , seat unit & headlight also the radiator & wiring looms are different .
Make sure you look in the 4xv & 5jj sections .
http://www.partzilla.com can be helpful for online parts micro fiches for getting part numbers & checking prices in the states as theyre prices are cheaper or you could try
https://www.fowlersparts.co.uk/browser/ ... bike/yzfr1
enjoy
