cooling fan temp kick in
Re: cooling fan temp kick in
between 105 & 112 degrees there is a thread about a switch that kicks the fan in sooner .
Welcome to the forum bud
Useually we like a newbie post to be a hello with a bit about the person , they're biking history & maybe a pic of the bike , like most you've proabaly not looked at the forum rules & guidlines , i don't think anybody ever does
Anyway bud join in the banter as the more you put into your posts and the forum the more you'll get out
Welcome to the forum Mike, as Jompy says, or monkey face as he is known, his avatar is actually a picture of him .... On a good day,
anyway as Jompy says, pop over to the newbie section and start a tread so we can all officially welcome you as a new member to our biking community.
The standard thermo switch should turn the fan on at 104°, but it was more like 108 on my bike. I thought that was a bit warm!
The thermo switch from an early Accord will fit and switches the fan at 91°.
pompousporcupine
- Bike Make & Model: R1 4xv
Holy Thread Revival!
Anybody got the year/part number for the early Accord switch? I saw temps of 109 over the weekend and the fan never kicked in.
I don't know part numbers, but I bought one for an '85 Accord and it's been fine.pompousporcupine wrote:Holy Thread Revival!
pompousporcupine
Thank you! Will give that a go and see if the fan kicks in.
On most bikes i wire in a manual override switch but i'd like to avoid that if i can
might be also worth replacing your rad cap and putting new coolant inpompousporcupine wrote: Wed Apr 24, 2019 10:24 am Thank you! Will give that a go and see if the fan kicks in.
- Rednine
- Bike Make & Model: S1000rr Sport
Welcome Biffo, looking forward to hearing a bit about your bike, where you are etc.
You don't stop riding bikes because you're old -you get old because you stop riding bikes.
Have you checked that the fan is working?pompousporcupine wrote:Thank you! Will give that a go and see if the fan kicks in.
I might get one tbh they mine does get hot - never overflows or refuses to cool down when the fan cuts in but i would prefer it to not get so hot. So ill have a look for 85 Honda Accord temperature sensor then.Moise wrote: Wed Apr 24, 2019 10:20 amI don't know part numbers, but I bought one for an '85 Accord and it's been fine.pompousporcupine wrote:Holy Thread Revival!
You will need to do some trimming to get the standard plug to fit. Otherwise it's a straight swap.polar wrote:I might get one tbh they mine does get hot - never overflows or refuses to cool down when the fan cuts in but i would prefer it to not get so hot. So ill have a look for 85 Honda Accord temperature sensor then.Moise wrote: Wed Apr 24, 2019 10:20 amI don't know part numbers, but I bought one for an '85 Accord and it's been fine.pompousporcupine wrote:Holy Thread Revival!
The only downside is the fan does run more often, so you're more likely to get hot air blown on you in slow traffic. But I did not enjoy sitting at the lights watching the temperature going up and up, waiting for the fan to come on.
You couldn't have a look on ebay for me could you and identify which one it is as ive had a look and there are different ones coming up for a 85 accord?Moise wrote: Wed Apr 24, 2019 8:21 pmYou will need to do some trimming to get the standard plug to fit. Otherwise it's a straight swap.polar wrote:I might get one tbh they mine does get hot - never overflows or refuses to cool down when the fan cuts in but i would prefer it to not get so hot. So ill have a look for 85 Honda Accord temperature sensor then.Moise wrote: Wed Apr 24, 2019 10:20 amI don't know part numbers, but I bought one for an '85 Accord and it's been fine.pompousporcupine wrote:Holy Thread Revival!
This is the one I bought: https://tridon.co.nz/products/Tridon/35 ... 292/TFS123polar wrote:You couldn't have a look on ebay for me could you and identify which one it is as ive had a look and there are different ones coming up for a 85 accord?Moise wrote: Wed Apr 24, 2019 8:21 pmYou will need to do some trimming to get the standard plug to fit. Otherwise it's a straight swap.polar wrote:I might get one tbh they mine does get hot - never overflows or refuses to cool down when the fan cuts in but i would prefer it to not get so hot. So ill have a look for 85 Honda Accord temperature sensor then.Moise wrote: Wed Apr 24, 2019 10:20 amI don't know part numbers, but I bought one for an '85 Accord and it's been fine.pompousporcupine wrote:Holy Thread Revival!
It's rebranded but I can't remember who the manufacturer is.
PS It looked too long to fit the R1 radiator but is directly opposite the inlet hose so fitted OK.
Duncan , does this look about right ?Moise wrote: Thu Apr 25, 2019 12:43 am
https://www.ebay.co.uk/itm/Radiator-Fan ... ect=mobile
or theses
https://www.ebay.co.uk/sch/i.html?_from ... h&_sacat=0
It should be a square connector, not round.
I couldn't see the links in Tapatalk, but all good now.
- Rednine
I experienced so much of that in the Island last year, as soon as I got back I replaced mine with an OEM part from Fowler’s and now all is good.Moise wrote: Wed Apr 24, 2019 8:21 pmYou will need to do some trimming to get the standard plug to fit. Otherwise it's a straight swap.polar wrote:I might get one tbh they mine does get hot - never overflows or refuses to cool down when the fan cuts in but i would prefer it to not get so hot. So ill have a look for 85 Honda Accord temperature sensor then.Moise wrote: Wed Apr 24, 2019 10:20 amI don't know part numbers, but I bought one for an '85 Accord and it's been fine.pompousporcupine wrote:Holy Thread Revival!
Hi Rednine what temperature does the fan cut in and out now?Rednine wrote: Thu Apr 25, 2019 10:09 amI experienced so much of that in the Island last year, as soon as I got back I replaced mine with an OEM part from Fowler’s and now all is good.Moise wrote: Wed Apr 24, 2019 8:21 pmYou will need to do some trimming to get the standard plug to fit. Otherwise it's a straight swap.polar wrote:I might get one tbh they mine does get hot - never overflows or refuses to cool down when the fan cuts in but i would prefer it to not get so hot. So ill have a look for 85 Honda Accord temperature sensor then.Moise wrote: Wed Apr 24, 2019 10:20 amI don't know part numbers, but I bought one for an '85 Accord and it's been fine.pompousporcupine wrote:Holy Thread Revival!
- Rednine
Pretty regularly at 105, never higher and fan kicks in immediately. It only ever gets to 105 in really hot weather and stopped in a traffic jam at the same time of which there are too many TT week and also getting out of race meetings!! Otherwise runs about 78 degrees
That was my experience with the standard thermoswitch also, except mine would get a few degrees hotter.
It just made me nervous to have the engine get that hot. If there was s problem with the cooling system, then your only about 10-15° from temps where you'd start to get worried.
