5eb to 5sl bottom end swap any tips
Recently brought my first big bike r6 2000 about 3months ago about 2 weeks ago engine made a funny noise and started to run crap had compression test done down on 1 and 2 striped it big chunk out of 1 and crack in cylinder 2 so been reading a few forums think I'm guna do 5sl bottom end swap any tips ?
Re: 5eb to 5sl bottom end swap any tips
Welcome in bud
There should be someone around that'll be able to help you but you've posted in the wrong section bud .
It's best to start off with a hello post in the newbies section with a bit about yourself and your biking history and then either post your question in the R6 or general section .
Best of luck
Best of luck
No worries bud , usually a lot more people say hi if you put a hello post
