Hello
R1 AlanM
Bike Make & Model: Yamaha R1
Hello
Post by R1 AlanM »
Hello all. Thought I would join this site as I have recently bought a 99 R1 on an 03 plate. Having had a 4 year absence from owning a bike I got the bug again and seen this beauty an fell hook line and sinker. I do have a few questions if anyone can help in any way.
The bike handles and rides very well but I have heard that fitting a steering dampner takes away the slight running wide feeling it gives from the front end....that and obviously its needing sticky tyres as the set on it are more of an all weather tyre...I am thinking on pirelli corsa 3's....that is only due to me always having pirellis on previous bikes mainly a suzuki gsxr 750.
The power deliver on this bike is nothing short of awesome...so I dnt need any help ther.
Other couple of wee issues are it needs a new nose fairing as the one on it has had a crack and a bad repair so I would like to source a new one for that....wer is best to get that.
The bike has a real nice tail tidy with nice led tail lights and indicators of which I have been trying to source a replacement buld for the tail lights...with no joy...ive put a photo ov the type needed if anyone has seen them before, also I have put a photo ov a buld I did source so it shows the difference between the one that fits (on left)
The seat cowel is nice but its a bit rattley and isnt flush fitting as I wld like...any options out there.
How do I put photos on here too...???
Sorry for the long winded hello... :lol: :lol: :lol: :x
Re: Hello
Hi Alan welcome ,easiest way to get photos on here is to use the tapatalk app ,few of the lads have bought fairing kits from China ,with good reviews check " triggers broom " three for one
Re: Hello
welcome in mate & good look getting her looking pretty again ;)
an R1 a day keeps insanity away :)
Re: Hello
Welcome in Alan
As far as i'm aware the steering damper is to stop the R1 from shaking it's head and the "run wide " feeling is something else .
Here you are for posting pic's
"get yourself a free photobucket account & follow the idiots guide to posting pics from your pc
posting.php?mode=reply&f=6&t=10659
if you don't want to open a photobucket account then an alternative is go to
http://tinypic.com/
1 - "choose file" and browse to the image you wish to upload from your PC
2 - In the "resize" drop down choose either 15" or 17" screen (15 is enough and fast too)
3 - Press "upload now" where it will ask you to type in a couple of words to confirm you are a human being and not an automated program.
4 - Once done copy the text from the "IMG Code for Forums & Message Boards" field
5 - Then just paste it exactly as is in to your message.
or you can post direct from your not so smart phone using tapawank (tapatalk) it's great for posting pic's & notifications but wank for viewing the forum ;)"
Re: Hello
Hi Alan, welcome to the forum.
With regards to the running wide issue, I think it's been mentioned on here about fitting the later top amd bottom yokes...possibly the 5pw, but don't take my word for it, maybe soneone will chip in shortly or just have a search on the forum.
Pete.
Re: Hello
Welcome in mate.
Re: Hello
Welcome to the forum Alan and good luck in sorting the running wide problem. Now I'm not at all technical but I have had some of my previous R1's running wide, I got the suspension set up and that sorted the problem, what they did was twiddle at the front and rear, that's the limit if my technical ability, they firmed the suspension up and the bike held its line.
Anyway welcome
Stephen :D
Re: Hello
Welcome, good to have another 4xv owner on board. Looking forward to some photos.
The running wide could be the tyres. But I'd suggest that you make notes of the suspension settings, then put everything to standard as a starting point, including the fork height in the triple clamps. You may need more preload though depending on your weight.
As others have said, a steering damper won't help.
Yeah, they do go well. [emoji3]
Sent from somewhere using Tapatalk
Re: Hello
Hi and welcome mate,
Great first post, :clap:
Re: Hello
"Those 4xv's are a lovely bike , they share a lot of parts with the 5jj like frame, wheels & engines are similar , things that are different are ECU , bodywork i.e. tank , fairing , seat unit & headlight also the radiator & wiring looms are different .
Make sure you look in the 4xv & 5jj sections .
http://www.partzilla.com can be helpful for online parts micro fiches for getting part numbers & checking prices in the states as theyre prices are cheaper or you could try https://www.fowlersparts.co.uk/browser/ ... bike/yzfr1
enjoy :)"
R1 AlanM
Re: Hello
Post by R1 AlanM »
Thanks for the welcome and all good info on the wee issues.
I did post a pic on that daft tapatalk but a dunno if it worked... :lol: :shifty: :shifty: :shifty: :shifty:
watzy160
Re: Hello
Post by watzy160 »
Welcome Alan. Enjoy! These guys are cool! :D
