"nd time Newbie
- Blue Camo
- Bike Make & Model: Yamaha R1 4c8
"nd time Newbie
Hey guys, been a while since I was last here, back in 2012 I believe. Sold my 04 R1 back then and recently (3 weeks ago) got myself an 07 model. 10,223 on the clocks, dripping with extras and all original parts included also. Couldn't remember my old details so have had to "re-join".
Live in Berkshire SL2 area so if there are people on here that fancy a ride out who are local then give me a shout. Also very handy with the spanners so can give others local a hand if needed.
Hope to get advice and give as well as that is what I do.
First post and first issue I have is regards the cold start. I know the 07-08 models are not the best starters and mine fires up roughly on the third rotation which I believe is normal for this model. The bit that I am a little concerned about though is right before it starts up the temp goes from reading "lo" to quickly flashing "hi" then back to "lo" then fires up. No issues with any of the running or running temp or fans , so no issues at all just the quick flash of "hi" when starting from cold. This doesn't happen every time on start up though, only if left overnight. If left for 2 mins or 2 hours it doesn't do it. Hot start is fine, spins up fast with no noises at all.
I have seen 3 people that also stated they had this issue but for the life of me can not find a definitive answer as to why it would do this.
Any help is greatly appreciated and received and hope I can be of some help to some of you guys and gals on here.
Akrapovic Carbon Cans, Akrapovic Carbon Tank Cover, Tank Infills, Heat Shield, Clutch Pivot Cover, Watsen Flushmounts, Pazzo Levers, Gilles Rearsets, Loads of ProBolt Gold R&G Tail Tidy and Crash Bungs and PC111
						- Donny
- Bike Make & Model: R1 2CR
Re: "nd time Newbie
Had a 4c8 for 5 years and always started easily and always on first press of the button, mate still has one and its fine as well, never heard of it being a dodgy starter TBH , there is an electrical connector that can get corroded and cause issues, trying hard tae remember were it is , under lhs fairing infill I think ?? check and clean that up, enjoy the forum and welcome back.
Re: "nd time Newbie
Welcome back with the new beast mate.  Not a million miles away in the grand scheme of things (hello from Hampshire). That's a weird one or perhaps not. Someone here will have an opinion or answer worth a listen I'm sure.
						- Blue Camo
Re: "nd time Newbie
Cheers guys, I know there are issues with the starter going bad and the usual 04-08 generator spinning its magnets (that happened on my 04), plus the wiring loom chaffing on the clock bracket but the "hi" flash I hadn't heard of. I'll strip and clean all the plugs and get some dielectric grease on them and see if that makes a difference.
I'll also run through the diagnostic mode and check the TPS setting and check the TB sync as well.
I'll also get some pictures up as soon as I have taken some of her lol.
Re: "nd time Newbie
Hi welcome back I've got an 08 and never came across ur symptoms look forward to photies though
				steveo916
- Bike Make & Model: Ducati 916 / R1 4XV
Re: "nd time Newbie
Hilo,
Welcome in.
Maybe your bike is just being polite and saying Hi to you when you start her up.
						Welcome in.
- Scrapman
Re:
+1samr1 wrote:Hi welcome back I've got an 08 and never came across ur symptoms look forward to photies though
				watzy160
- Bike Make & Model: Yamaha r1 50th Anni
Re: "nd time Newbie
Welcome in dude. Lets see some pics!
As Donny said, maybe worth checking that connector.
- Blue Camo
Re: "nd time Newbie
Well decided to bring the R1 to work tonight, went to start it and guess what? That's right no flash to "hi" on the temp display when starting. Could it be because I grassed it up? Doesn't want other people knowing its a temperamental b1tch lol.
Pictures now uploaded to the picture thread. Enjoy!
Re: "nd time Newbie
Temperamental tarts they are. Gotta love em mate!!
