Stator assy wows
nuggs1000
Bike Make & Model: R1 2003
Stator assy wows
Post by nuggs1000 »
I have a 2003 R1 , I had an issue around 6 weeks ago , when I lost all power , I got the bike recovered to home , on the advice I had from twiggers in Loughborough , he advised me to replaced the battery if I was replacing the rectifier , I still ended up having charging issues , which only meant replacing the stator .
The stator assy won't come off , he's used heat and even used the correct tool from Yamaha ,.any ideas would help
Re: Stator assy wows
Welcome in Stephen
Wow that's a long time between joining and your first post , 5 years 😱😂
Sorry to hear of your problem with the stator , hope you get it sorted soon 👍
Maybe hot and cold - difficult to explain but it involves heating up the unit then poring cold water over to shock it
How do you know it's the stator?
There have been members here who have removed rotors on the older R1's - hopefully one of them can help.
nuggs1000
Post by nuggs1000 »
The bike is at twiggers in Loughborough , he tested the stator with the bike turned over and found it was the stator , he's tried all the tools he has , he's tried applying heat , but it still won't move , he even brought the tool Yamaha recommend.
Probably need to shock it.
The rotor is on a taper and located with a woodruff key.
You screw the puller bolt into the middle, hold the rotor still, either with a special tool or a strap wrench, tighten the puller bolt really tight then smack the end of the bolt hard with a deadblow hammer, try some heat /cold and repeat, it should pop off.
nuggs1000
Post by nuggs1000 »
Hi
Thanks for all comments , would a cover off a 2004 fit a 2002 / 2003 model , as I'm finding it difficult to source a part second hand to suit mine , maybe it's because it was only out for 2 years .
no but 4xv & 5jj should
Kylezx7r
Stator assy wows
Post by Kylezx7r »
Get it fucking hot then get it fucking cold soon straight after then repeat this process as many times as it takes. Try to apply the heat with the puller tight so its trying to pull the flywheel off as you heat. Keep giving it more pressure with the tool
nuggs1000
Post by nuggs1000 »
Hi
The mechanic has finally been able to remove the cover
nuggs1000 wrote: Sun Oct 14, 2018 8:42 am Hi
Glad you've got it sorted buddy 👍
