R1 1998 carb float settings
MotorMouse46
Bike Make & Model: R1 yzf 98
Post by MotorMouse46 »
Just serviced and replaced needle valves on my 98 R1
Anyone know if there is a measurement for the float setting, rather than filling it with fuel and adjusting the float.
Loving this site 😊
Re: R1 1998 carb float settings
Yes, there is a method using the float height. It is tricky though, as you have to hold the carbs at the correct angle as they are almost downdraught.
There is no Yamaha spec, but I have some tuning info from Factory Pro that gives 9.5 mm. Check your needle valves first and replace if they show any wear.
If you PM me your email, I can send you all 3 pages.
