4xv no spark
mrfixit r1
4xv no spark
Post by mrfixit r1 »
Don't seem to be getting a spark , replaced pick up
And got power at coil packs , ecu is fine ???
Also if the fuel pump is wired wrong will this make it ground the earth ??
Cheers lads
Re: 4xv no spark
dude this is the newbies section you need to be finding the appropriate section to post in !
the HT leads can break up when old where the plug cap screws on & cause misfire all you need to do is cut 5-10 mm off the end & screw the cap back on .
mrfixit r1
Re: 4xv no spark
Could find my way round site lol .. On iPhone :violin:
Re: 4xv no spark
I've moved one of your posts to the correct section
Re: 4xv no spark
Good luck with getting it fixed Mick . It's a bugger navigating the forum on an I phone, do you use tap talk ... Clarky can give you some tips on that, he is our expert on that
As I say, good luck
Re: 4xv no spark
Steve R1 wrote:Good luck with getting it fixed Mick . It's a bugger navigating the forum on an I phone, do you use tap talk ... Clarky can give you some tips on that, he is our expert on that
As I say, good luck
Is it that different on the iPhone ? On the HTC useing google chrome it just comes up the same as on a computer , I didn't realise the iphones were THAT wank , tapawank (tapatalk) maybe worth a try then
Re: 4xv no spark
As I say, good luck
I too can get it up just like it is on a computer, but tap talk seems a bit better in the phone , a bit faster
mrfixit r1
Re: 4xv no spark
Steve R1 wrote:
As I say, good luck
trust its wank lol :clap:
Re: 4xv no spark
I'm just about getting used to it now, means I can contribute when I'm not at home[emoji3]
Ok I hear you all saying.... That's why it's wank [emoji79]
