Hi every1 im new on here and need some help
Tried to change stator cover and droped washer and spacer into engine can some one help or know any1 im in Barnsley Yorkshire
Re: Hi every1 im new on here and need some help
That'll either be lower a magnet in behind it on a cord or sump off then. How a bout an extending magnet stick thingy?
Chaos.....panic......destruction.......my work here is done!
Thanks for reply i did try a screwdriver wi magnetic tip but had no joy
Welcome in Jamie
Hope you get the washer and spacer out , maybe a sump off job
I rubbish at messing with anything mechanical i hope its not going to be costly
If it's anything like the 4xv then you'll want 4 exhaust manifold gaskets , i like the copper onesSpartan wrote:I rubbish at messing with anything mechanical i hope its not going to be costly
http://www.ebay.co.uk/itm/YAMAHA-YZF100 ... XQydtTLa2J
Or
http://www.ebay.co.uk/itm/YAMAHA-YZF100 ... Swux5YLxI~
And Athena sump gasket
http://www.ebay.co.uk/itm/SUMP-GASKET-A ... SwZ1BXc50D
Or o.e.m
https://www.fowlersparts.co.uk/parts/view/5VY-13414-01
Sump crush washer o.e.m
https://www.fowlersparts.co.uk/parts/view/214-11198-01
Obviously depends on what model R1 you have as you haven't told us & don't over tighten the sump cover bolts or the sump bolt , the sump bolt for some reason has the wrong torque settings in the workshop manual , it should be around 15-20nm not the 40nm stated you should just feel the new sump crush washer squishing
How can the people who write a manual make such an important mistake!!! 40nm is pretty much the torque setting for a something like a sump oil drain plug which is 17mm not something like the sump bolts which are what, 10 or 12mm?jompy wrote: the sump bolt for some reason has the wrong torque settings in the workshop manual , it should be around 15-20nm not the 40nm stated you should just feel the new sump crush washer squishing
Most of the parts listed in my post will fit the 5vy but if you do want to buy them shout up and either i will or someone else will check them for you .Spartan wrote:Hi its a 2004 5vy model if that helps any
Have you thought about trying an endoscopy camera ? You can get them on Amazon for around £15 for android devices
You'll need to download cameraFI from Google play for free to use it
https://www.amazon.co.uk/Endoscope-LESH ... opy+camera
Mate sorry i wasn't very clear , 40nm is for the sump plug bolt but it's WAY too high , using 40nm on the sump plug bolt is a sure way to strip the thread which then cracks the sump , i have the a repaired sump cover to prove it and it's quite common ask 2002r1jon !Exuptoy wrote:How can the people who write a manual make such an important mistake!!! 40nm is pretty much the torque setting for a something like a sump oil drain plug which is 17mm not something like the sump bolts which are what, 10 or 12mm?jompy wrote: the sump bolt for some reason has the wrong torque settings in the workshop manual , it should be around 15-20nm not the 40nm stated you should just feel the new sump crush washer squishing
Shame your so far away bud it would have been nice to have met you at the bar-b-q , Jen speaks highly of you
jompy wrote:Most of the parts listed in my post will fit the 5vy but if you do want to buy them shout up and either i will or someone else will check them for you .Spartan wrote:Hi its a 2004 5vy model if that helps any
Thats a pretty good idea i might have a look at the camera thingy, but really i wanted some one close by to come have a look for me because im useless lol
Theres a couple of motorbike shops but they will probably rip me off and say its a lot if work and what not
