Hello
Re: Hello
No worries Jamie , not everyone spouts verbal diarrhea like I doJum wrote: Sat Mar 10, 2018 6:01 pm Sorry man of little words
Thanks for letting me join will be
Doing a lot of reading of post geting some ideas
Ridding a Thunderace at moment been thinking about changeing to a r1![]()
One of the other guys has got a thunderace as well as his R1 s I guess you may be chatting to him
Somewhat model R1 you going for ?
Re: Hello
Welcome to the forum Jamie, and thank you for such s long and interesting introduction.... lol
Seriously.... ignore me.... the rest of the guys n gals do...
This is a great forum.... well actually... we are more like a biking community... I’m being serious now... people on here are very knowledgable and helpful... so any questions.... just ask
Please forgive my strange sense of humour on the first line.... we do like s giggle or three on here from time to time
Re: Hello
welcome to the mad house I’m a newbie myself loads of good info and banter on this forum.jompy wrote: Sat Mar 10, 2018 6:12 pmNo worries Jamie , not everyone spouts verbal diarrhea like I doJum wrote: Sat Mar 10, 2018 6:01 pm Sorry man of little words
One of the other guys has got a thunderace as well as his R1 s I guess you may be chatting to him![]()
Try and get on with Jompy I think they put him in charge cos he’s no good at anything else
Re: Hell
4xv is awesome you’ll see a massive jump from the ace I did. It’s a smile a mile. Have a look at 4xv full restoration post it’s a bit like war and peace but it’s a bloody good read (don’t tell him I said so ). exup valves can stick but easy fix and they can jump out of gear from 2nd to 3rd (worn dogs on the gears or a week spring) again it’s fixable depends on how much you’ve got to spend and how much work you are prepared to do. The older ones are now getting a bit pricey but you might get lucky. Don’t rule out newer models there are often better bargains to be had as they are not yet “collectible “ good luck.
Re: Hello
Where to start
Don't be put off with the replys these are an 18-20 year old bike .
First bit of advice , unless you absolutely have to have a 4xv for the sake of having a 4xv (understandable) go for a 5jj , it's virtually the same bike but 4xv's are becoming stupid money which is pushing up 5jj prices and the 5jj has a better midrange although it's only a case of changing the pilot jets !
You can usually tell if one's been dropped as it will have whiteness marks/ dints on the swing arm where the rearsets have hit the swingarm .
As said they can jump out of second gear , Markypvs sorted his 5pw second gear in the thread "triggers broom" ( more or less the same bottom end) and it was around £350 for parts and it's an engine out job but is not hard apparently ( covered in the $300 R1 thread ) of someone said it was £800 at his local garage bugger quotes .
Carbs can sometimes be a problem because of their age , ginger Jon is stripping them , ultrasonic cleaning and rebuilding them with new seals for around £100
5jj engines are virtually exactly the same as the 4xv and are interchangeable and I believe the 5pw bottom end is interchangeable too but make sure you get that confirmed first .
Bodywork , tank seat and rear subframe are different between the 4xv & 5jj .
You missed a nice 98 blue 4xv that went for £2500 on here last month .
Have a bloody good look through the 4xv &5jj sections they're a wealth of knowledge .
Also try "$300 R1" also in the projects section
viewtopic.php?f=38&t=17416
Re: Hello
Didn’t mean to sound negative it’s just what’s happened to mine the gearbox job wasn’t that expensive but I did drop the motor out myself. Just needed two new gears. They are great bikes. Sorry Jompy.jompy wrote: Sat Mar 10, 2018 9:39 pm Where to start![]()
Re: Hello
No mate I was on about my post sounding negativeDanf1 wrote: Sat Mar 10, 2018 10:36 pmDidn’t mean to sound negative it’s just what’s happened to mine the gearbox job wasn’t that expensive but I did drop the motor out myself. Just needed two new gears. They are great bikes. Sorry Jompy.jompy wrote: Sat Mar 10, 2018 9:39 pm Where to start![]()
viewtopic.php?f=38&t=17416![]()
2nd gear is a must check
In the past when people have asked what to look out for they've been put off , like I said these bikes are 18-20 years old
Re: Hello
Hi jum and welcome,
the 4xv's are getting very collectable and you will see from the pricing dealers are starting to think they are made of gold. privately you are looking anware from 2.5k to 5k will get you something nice that will need tlc for the rest of its life.
I owned a 2004 R1, the underseat piped version and they are going for little money considering how good the bike is. I would defo have another one.
Re: Hello
I love my 4xv, but if I was to do it again, would probably buy a 5pw. You get pretty much the same engine, less weight, and sorted suspension and steering. They aren't as mental as the 4xv, but then tankslappers and wheelies on bumpy corner exits lose their novelty after a while.
I can't believe I just wrote that.
It really depends what you want though. I ride my bike quite a lot and do a few trips a year, so did sort the rear suspension. But if you just ride on fine Sunday afternoons for a couple of hours, then why not have a 4xv. They are fun!
There was a good feature in Performance Bikes last year on the R1, you can still download a copy.
