abs removal 2015 r1
Dig1414
Bike Make & Model: Yamaha R1 2015
abs removal 2015 r1
Post by Dig1414 »
Hello, I hope there's somebody who can help with this problem. I recently purchased a abs delete module from velox racing, to fit it the pump has to be removed, the problem is the module forms part of the under tray and removing it will leave a large hole. Doe's anybody know of a company that sells a sealed unit, I've done quite a bit of searching on line and came across a YouTube posting from sportsbike track gear were there doing the same project, and on there bike it's a sealed unit. The problem is I can't find anybody who has one, I've tried a number of race bodywork people, Yamaha dealers, and velox racing, if anyone knows of a company that sells the under trays or has done a similar project any reply would be greatly appreciated, thanks.
r1Mike
Re: abs removal 2015 r1
Post by r1Mike »
I think we may have chatted on email today, CRC do a race seat unit and the undertray may fit, you could also try hotboddies in the USA
I will keep looking
PICOB
Post by PICOB »
Is it a standard rear subframe and undertray? I've just taken mine out and the only hole left is the locating pin on the bottom of the pump which isn't large as such and can be easily bunged up. Have you removed too much by any chance?
