Frame marks
Frame marks
Firstly I’m new so want to say hello to everyone on the forum I’m currently riding a 2003 R1 absolutely love it
but I have couple of problems so I’m hoping someone on here can point me in the right direction. I have like water marks on the frame what could I use to try and remove them? I’ll attach a pic. Also when I pull of on the bike it’s like it’s got a flat spot if I don’t rev it enough is that normal on a R1 or would u say I have a problem somewhere I haven’t serviced it yet it’s currently on 19k on clocks thanks for your help
Re: Frame marks
Welcome in pal [emoji106] i always need a few revs on if im trying to pull off 'quickly'. Ooh matron [emoji54]
Re: Frame marks
Welcome in Levi
Hope you enjoy the forum , nice 5pw
I take a guess that somebody's used muc off and not cleaned it off right away , to be honest having never had a black frame i wouldn't want to suggest anything just in case of a mishap but i would say what ever you try do it on a part of the frame you can't see
As for the flat spot first thing i'd be doing is checking the Exup valve is working and set up properly .
Re: Frame marks
Hi thanks for the reply’s little update what I’ve noticed after just having a little blast on it if I pull the clutch in when I rev it it’s fine when the clutch is out I have this kind of blip sorry if it doesn’t make sense it’s so hard to explain
Re: Frame marks
on my 5PW (Triggers broom) on here , i used black T cut then black trim wax, as for the flat spot, could be the exup valves or the throttle bodies need balancing.
Mark
Mark
Im not overweight im under height !!
Re: Frame marks
Welcome aboard.
I'd try a splash of wd40 on a microfiber cloth first to try and remove the frame staining,
Re: Frame marks
Ok thank u lads for ur reply’s I’ll try using them 2morrow and let u know how I get on and I’ll get a Mecanic to take a look once I can get it booked in
Re: Frame marks
Exup check should be easy enough to do yourself using the service manuals , unfortunately the links to the service manuals on here are broken but most R1 facebook pages have them to download for free in they're files sectionsLevi1982 wrote: Sun May 17, 2020 8:24 pm Ok thank u lads for ur reply’s I’ll try using them 2morrow and let u know how I get on and I’ll get a Mecanic to take a look once I can get it booked in
Re: Frame marks
What’s this?jompy wrote: Sun May 17, 2020 9:05 pm ....unfortunately the links to the service manuals on here are broken but most R1 facebook pages have them to download for free in they're files sections
Go to FB
Re: Frame marks
Hopefully they'll be sorted in the next few daysHorus-222_R1 wrote: Mon May 18, 2020 5:40 amWhat’s this?jompy wrote: Sun May 17, 2020 9:05 pm ....unfortunately the links to the service manuals on here are broken but most R1 facebook pages have them to download for free in they're files sections![]()
Go to FB![]()
Re: Frame marks
Welcome to the forum Levi, good luck with sorting your flat spot and the marks on your frame. Don’t use muc off on your bike, autoglym, whilst more expensive, is a lot kinder to your bike [emoji1303][emoji4]
Re: Frame marks
I sorted the same flat spot on my 4XV with new plugs, I also unscrewed the plug caps and cut 10mm off the ends of the plug leads while I was there.
Re: Frame marks
Plus one on a wipe over with something oily for the frame marks. I use acf50 or Autoglim bumper gel.
There’s a bunch of “ back to black” type products out there.
Re: Frame marks
Thanks Boz wd-40 abd a scrubbing brush then used black T-cut there very faint now as didn’t wanna scrub the frame to hard incase it went wrong but I’m happy now as there hardly noticeable
Re: Frame marks
Looking good Levi [emoji1303][emoji122][emoji4]
Re: Frame marks
Levi1982 wrote: Sun May 17, 2020 10:41 am Firstly I’m new so want to say hello to everyone on the forum I’m currently riding a 2003 R1 absolutely love itbut I have couple of problems so I’m hoping someone on here can point me in the right direction. I have like water marks on the frame what could I use to try and remove them? I’ll attach a pic. Also when I pull of on the bike it’s like it’s got a flat spot if I don’t rev it enough is that normal on a R1 or would u say I have a problem somewhere I haven’t serviced it yet it’s currently on 19k on clocks thanks for your help
All sorted now all service and parts manuals are in hosted by velox racing and in the relevent sections , thanks MikeHorus-222_R1 wrote: Mon May 18, 2020 5:40 amWhat’s this?jompy wrote: Sun May 17, 2020 9:05 pm ....unfortunately the links to the service manuals on here are broken but most R1 facebook pages have them to download for free in they're files sections![]()
Go to FB![]()
Re: Frame marks
All sorted mate I serviced the bike runs like brand new no flat spots at all thank younewsh wrote: Mon May 18, 2020 11:46 am I sorted the same flat spot on my 4XV with new plugs, I also unscrewed the plug caps and cut 10mm off the ends of the plug leads while I was there.
