carb starvation ?
bladebuster
Bike Make & Model: yzf r1 2ooo
carb starvation ?
Post by bladebuster »
cheers luke03r1,hi guys jst joined yesterday and am looking for anyone with a 2000 r1 who,s had any probs with their bike being starved of fuel,me bike developed this annoying trend a couple of years ago,wen the bikes hot the idling drops then it cuts out,also if the bikes temp is over 70 and you turn off the engine it wont start until it has cooled rite down,it really struggles to start and it sounds as if the engine is being starved of fuel,i kno a guy with a zx10 who has the same prob and he called it carb sync,not sure wot this means,any helpful hints or tips wud be mucho appreciated ,cheers all,safe riding ,bladebuster,i,ve also had the carbs stripped,cleaned and balanced but the problem is still there,
Re: carb starvation ?
Welcome in Paul
Carb sync is what it implies syncing the carbs so they work together, eg balancing.
Anyway enjoy the forum and I am sure help will be along soon
Welcome in Paul ;)
As Pete says above synching is the same as balancing :D
stug
Bike Make & Model: 2006 R1
Post by stug »
Not starting when hot could be problems with the valve clearances, possibly needs the shims checked.
How many miles on it and have the valve clearances ever been done?
stug wrote:Not starting when hot could be problems with the valve clearances, possibly needs the shims checked.
+1 check your service record to see when shims were done
bladebuster
hi stug thanks for the advice,30k on clock and a dont think the valve clearances have bin dun,i kno the lst owner so wl get this checked,thanks again blade buster
