intermitant spark r1
Hi, my name is jason from merthyr in s wales ive got a 53 plate r1 been standing for a few months went to start it yesturday it did try to fire then made a popping sound then wouldnt fire at all. so i drained the petrol and put new in thinking the petrol was dead,still wont fire so checked the plugs and ive got a intermitant spark now can any one Help me please
Re: intermitant spark r1
welcome in Jason
Check the leads , at the plug cap end the leads tend to come loose try pushing the or screwing the plug cap back on , some times you need to cut a little off the lead to make it screw on better & connect
Welcome in Jason
After trying Jompys suggestions,then try new plugs mate
Hi i will try both suggestions thanks its a nightmare at the moment..2002r1jon wrote:Welcome in JasonAfter trying Jompys suggestions,then try new plugs mate
Hi thanks for your reply will try this after work tonight cheers..jompy wrote:welcome in Jason
Cool I hope it is just a simple fixjoshsam8 wrote:Hi thanks for your reply will try this after work tonight cheers..jompy wrote:welcome in Jason
hi jompy i rested the plugs on the body and found the sparks were jumping through the coil packs thats not rite is it ????jompy wrote:Cool I hope it is just a simple fixjoshsam8 wrote:Hi thanks for your reply will try this after work tonight cheers..jompy wrote:welcome in Jason
nope thats not right at all looks like your leads are breaking downjoshsam8 wrote:hi jompy i rested the plugs on the body and found the sparks were jumping through the coil packs thats not rite is it ????jompy wrote:Cool I hope it is just a simple fixjoshsam8 wrote:Hi thanks for your reply will try this after work tonight cheers..jompy wrote:welcome in Jason
HI, just to let all your boys now my r1 is up and running now cant wait for dry weather
nice one buddy & thanks for letting us know you got it sorted , did you need new coils ?joshsam8 wrote:HI, just to let all your boys now my r1 is up and running now cant wait for dry weather
What was the reason then?
HI, everyone as i said sparks were jumping through the coils and not down the plugs so
me and my mate pulled the rubber boots off them and found a brilliant spark popped to halfords bought four new plugs and now its never sounded so sweet but everything was pointing to the coils always take those boots off the coils befour you buy boys
