New from Weston-super-mare
L31ghs
Bike Make & Model: Yamaha R1
Post by L31ghs »
hi just joined from Weston-super-mare, I've ride a 2002 R1 that I've had for 6 1/2 years. I'm looking for help before I start it, as its been left for 18 months :naughty: then looking to get back on the road with new and old friends so any help or advice would be great fully received and any help or advice I can give I will
Re: New from Weston-super-mare
Hi Leigh and welcome to the forum mate, has it been started in the last 18 months, how was it running before, give us a bit of background on the bike and i'm sure the guys on here will give you plenty of help, oh and piss taking :lol: we do like a good bit of banter on here :D
L31ghs
Post by L31ghs »
It was mint before just don't want to start, i was thinking of just topping up a little oil cus its probably all dry at the top??I was thinking of putting it straight in for a service, I'm going to drain out the old petrol and replace with new and replace the battery ( I was on a trickle charger but the charger knackered about a year ago
CBXTrev
Post by CBXTrev »
Hello there, welcome to the forum
Welcome in Leigh
Like you said , drain tank & carbs then replace fuel . Turn over a few times on the starter then fire it up , run some pro fst through it to clean the carbs . To be honest it should start on the fuel that's in it but the fuel will be wank
Welcome to the forum pal
Sent from my iPhone
Hi mate, welcome to the forum. Good luck with getting the bike started. If you haven't ridden fir 18 months you may be a bit rusty, so take it easy.... No offence meant.
Also post some pics, we love pics on here
welcome to the forum, 18mnths :? .
oil fuel, fluids etc and be carefull with the tyres, cold concrete 18 mnths they are going to be like rocks
L31ghs
Post by L31ghs »
Thanks for the responses I was going to put fresh boots on (the rear had a puncture which was temp repaired to get me home) did you mean turn it over a couple of times before starting??
Welcome in Leigh.
You want to spin her over without starting just to get the oil around the mota.
Deffo change oil, coolant and brake fluid, take pads out and clean them and the disks/calipers. If standard brake lines I would change them as well, like me they are getting on a tad ;)
L31ghs wrote:Thanks for the responses I was going to put fresh boots on (the rear had a puncture which was temp repaired to get me home) did you mean turn it over a couple of times before starting??
PJC wrote:Welcome in Leigh.
yep like PJC says spin her over a few times to get the oil round it before firing up , you can do this buy taking the plug caps off or if your draining the fuel from tank & carbs anyway do it while the carbs are empty ;)
Hi mate welcome
welcome in Leigh ;)
As these lot above state,but i would flick the "ON/OFF" switch onto "OFF" then turn it over for a few seconds a few times to get the oil round,but it will need new fluids at the very least mate
Siamblue
Post by Siamblue »
Hi Leigh and welcome,i had a good ride once in Weston,just behind the college :whistle:
Welcome in mate. Like others have said replace all fluids and brake lines if rubber.
welcome in Leigh ;)
but dad I thought if the kill switch was in off position the bike would be completely dead , I can't remember properly as I never use the kill switch !
Not sure if ive ever done it TBH :lol: maybe not then :think: f**k knows :lol:
Let us know how you get on Leigh
