Front Brake issue
TT2014
Bike Make & Model: Yamaha R1
Front Brake issue
Post by TT2014 »
Hi,
I have a problem with the front brake on my 2003 R1. The brake works very well but the lever won't pull in far enough to activate the brake light. So I have to use the back brake to activate the brake light. The pads are in good condition, 5.6mm depth remaining on each. The switch is in a fixed position so can't be moved. I've also had the pads out and worked the pistons, they move freely and are in very good condition. The front wheel spins freely.
Please help, Thanks.
Re: Front Brake issue
Not the best intro I have ever read, Try again sir and you may even get some answers :lol: :lol: :lol: we are nice honest and only bite now and then :shifty:
Pics biking history etc always goes down well on here ;)
Do you hear the clicking sound of the micro switch, if not remove and clean it ;)
TLS_Russ
Bike Make & Model: 99 R1 4XV
It’s my birthday
Post by TLS_Russ »
My guess would be the tip of the little plastic plunger that activates the switch has broken off, probably when changing the brake lever, new switch will cure it ;)
Or..... its another case of crappy chinese levers :doh:
Hi my name is ? i ride a 2003r1 (pics attached) i live in?
I was hoping i could get an answer to a wee prob i have?
Hello and welcome manners are free so introduce yourself and start again :snooty:
This is soooooooooooooo why i love this forum :D
Newbies is a section to introduce yourself to the members,once thats done,most then move onto the techy questions in the correct areas for the question ;)
Soooooo say hello,let us know a bit about your biking history,pics etc,and then we will all be happy as pigs in sh!t :D
Hi mate.
Had the same problem on my 14be, it was the brake light switch that had broken so replaced it and now it works. :P
As peeps say... Some pics and biking history in newbies section will go down a treat.
