Hi Folks
- pukmeister
- Bike Make & Model: 4XV & R1200GSA
Hi Folks
Hi everybody,
I've just returned to the Yamaha fold after a ten year absence, picking up a 4XV from 2000 with 29k on the clock. She's a bit of a shed at the moment having been a commuter hack with cracked/badly painted plastics and forks/mudguard from a 2003 model with the anodised black lowers. She sounds smooth enough when running but badly needs TLC to return her to her original condition. First to go is the minging iridium double bubble.
Plans are to source the correct forks ( then eBay the wrong ones), get the WP rear shock rebuilt, powder coat the corroded wheels and get the plastics welded and painted. She's in the popular red/black/white colour scheme. Should be a nice project for the next 6 months and then be a keeper once finished. She must be one of the last 4XV's before the 5JJ were introduced in 2000.
I'll probably be found lurking in the 4XV section or asking stupid newbie questions. Thanks in advance for any help offered.
I'm in Fareham, Hampshire by the way.
- Luke03R1
Re: Hi Folks
Welcome in buddy
Ask as many silly questions as you like I promise not to take the piss[emoji6]
Re: Hi Folks
U fecking liarLuke03R1 wrote:Welcome in buddy
- Luke03R1
Re: Hi Folks
[emoji56]samr1 wrote:U fecking liarLuke03R1 wrote:Welcome in buddy
Re: Hi Folks
Sam mate, you took the words right out of my mouthsamr1 wrote:U fecking liarLuke03R1 wrote:Welcome in buddy
Re: Hi Folks
Welcome in Adam
How about a set of chinese fairings ? £350-400
heres the standard early R1 newbie reply for you & how about starting a thread in the projects section with plenty of pics ?
Those 5jj's are a lovely bike , they share a lot of parts with the 4xv like frame, wheels & engines are similar , things that are different are ECU , bodywork i.e. tank , fairing , seat unit & headlight also the radiator & wiring looms are different .
Make sure you look in the 4xv & 5jj sections .
http://www.partzilla.com can be helpful for online parts micro fiches for getting part numbers & checking prices in the states you can then enter the partnumber into O.E.M part search on places like http://www.wemoto.com
enjoy
enjoy
Re: Hi Folks
Oops forgot to welcome you in on my earlier post
- welcome to the best yamahar forum in the world
Re: Hi Folks
Welcome in mate.
Re: Hi Folks
Hi and welcome neighbour, I'm down the road in Southsea.
Enjoy the forum
Dave
Enjoy the forum
Dave
Re: Hi Folks
Welcome to the mad house Adam, ask all the questions you want, someone will have the answer.
Post up some pics if your bike. To do this follow the link below ....
viewtopic.php?f=4&t=144" onclick="window.open(this.href);return false;
So welcome
Wallace
So welcome
Wallace
