hello to one and all
maddog82
Bike Make & Model: r1 5jj
Post by maddog82 »
hi, .. my names luke ,... and im an alcoholic ..... OH WAIT WAIT ....wrong forum lol
ok ill start again, .. hi guys, .im luke and i ride a 5jj, .. well i bought her in dec last year and rode on the roads for a while, .. but with feeling how well the bike rode i needed to unlock its potential and ride it the way it was built too, so now she's my race bike in the NGRRC pi1300 class. #82
so far i have rebuilt the engine from the bottom up, new shell, mains, rings, top end refresh with kent cams, and tuned to suit, home brewed pipe using stock headers, .. i cut out the merge chamber with that heavy exup and made my own collector, into a yoshi mid pipe and A16 end can, .. but im now waiting for my full yoshi system to come in the post, ... also upgraded the rear shock to ohlins, keyless ignition system, DBR adjustable rear sets HEL braided lines, i have a fair few more mods i'd like to do but its just time.. money and figuring out how to do them.
thanks for reading :)
Re: hello to one and all
Welcome in Luke :) - someone's been a busy boy ;) ;)
Get some pics up when ya can pal :) & enjoy the forum
maddog82
Post by maddog82 »
hi thanks, ... yh, she's got alot more mods done, .. but nothing really important, .. :) ok ill try put some up :)
maddog82
Post by maddog82 »
851850849848847
hope you like it
Welcome in Luke
i love the early R1's , i think i'd be happy owning upto a 5vy , how long you had your 5jj ?
maddog82
Post by maddog82 »
i have a big love for them too, .. ive not ridden an R1 newer so this is all i know, but love it, .... i bought it in Dec 2014, 852
same with me , my 4xv is all i need , well that & a trail bike ;)
theres a few things to know about owning 4xv's & 5jj's but i get the impression you've owned them previously
maddog82
Post by maddog82 »
i'd love a 4xv, ... actually no this is my first, .. but im switched on, and a mechanic by trade, so noticing any issues when they arise is fairly quick, gearbox is good, and front brakes seemed to like sticking, .. so done a strip down, clean and rebuild on them and now they are good,
mods over winter will be custom made yokes with 31mm offset which my mate will be machining up for me, front shocks will be full k-tech, even tho ive only recently bult the engine i will be pulling the head off, porting it, knife edging the inlet ports aswell as a bit more head work and im hoping to try and find someone in the UK who can raise the RPM limit on stock CDI, if i can get that done then ill do uprated valve springs, etc, i'd also like to put coils sticks (from the 5pw i think) and finding some way of having an adjustable ignition timing control on it,
maddog82 wrote:so far i have rebuilt the engine from the bottom up, new shell, mains, rings, top end refresh with kent cams, and tuned to suit, home brewed pipe using stock headers, .. i cut out the merge chamber with that heavy exup and made my own collector, into a yoshi mid pipe and A16 end can, .. but im now waiting for my full yoshi system to come in the post, ... also upgraded the rear shock to ohlins, keyless ignition system, DBR adjustable rear sets HEL braided lines, i have a fair few more mods i'd like to do but its just time.. money and figuring out how to do them.
There's quite a few happy 4xv and 5jj owners here. And a couple of knowledgeable ones if you have any questions (not me!).
Just curious, did you check the gearbox when you had the engine apart? How was 2nd gear?
maddog82
Post by maddog82 »
yh been looking through all the threads, it seems there is some good info on the forum, ... yh i had a look at it when i pulled the engine apart, there was a bit more than usual wear on one of the selector forks, so i replaced that, and the gear was a little worn, ,, i gave the gears to my mate who is an engineeeeeeeeeer and he undercut them so its all good now :)
Welcome in mate. Trust me you will be an alcoholic after joining this place! These guys will drive you to drink!
maddog82
Post by maddog82 »
thanks colin, ..
like moise i know a bit about the 4xv & 5jj but some of the guys on here like Alex_H , Mezzer & r1aoc really know they're onions , personally i'm happy with a standard engine but i know theres a lot more potential .
as great as the 4xv is from what i've seen i'd have to say from standard the 5jj is the better bike due to power delivery !
theres a few threads on the differences on the two models , the 5jj has a better midrange which i love but for some it makes the 8-9000 rpm hit of the 4xv feel a bit more tame as the power delivery is smoother . If i remember correctly the main jests on both bikes carbs are the same but the 5jj has bigger pilot jets .
here's the standard post i put up to new owners of the 4xv & 5jj models , i hope it helps
" Those 5jj's are a lovely bike , they share a lot of parts with the 4xv like frame, wheels & engines are similar , things that are different are ECU , bodywork i.e. tank , fairing , seat unit & headlight also the radiator & wiring looms are different .
Make sure you look in the 4xv & 5jj sections .
http://www.partzilla.com can be helpful for online parts micro fiches for getting part numbers & checking prices in the states you can then enter the partnumber into O.E.M part search on places like http://www.wemoto.com
enjoy :)"
welcome in bud
bekenafa
Bike Make & Model: R6 2009
Post by bekenafa »
Hi pal
Hi Luke
maddog82
Post by maddog82 »
hi guys, ... hanks jompy, .. yh the 16 pin connector is ok... one which did cause a small issue was in the same area but a 2 wire connector, light brown/red & red which is for the ignition, ... any way i done away with that now as i have removed the ignition and wired my kill switch to be my ign power on/off and it works a treat,
there is a huge amount of potential to tune these bikes a friend of mine has a 4xv which he races in the same class as me, his was a bsb from new and never a road bike his bike is kicking out 193.11 bhp (at the crank) its a weapon !!!
with these bike most of the power is released within the head work. my local dyno guy and good friend can tune a standard bike with a full system to get 171 bhp (at the crank) just by working the carbs, if any of you are near highbridge in somerset its worth looking up johnathan burt from new road motorcycles .. he's your guy!
if you guys want to unlock a good bit of power then just go ahead with top end work, ... porting & flowing, + knife edging cutting down valve stems ... we use kent cams (yam17 to be specific) a +4 igntion advancer, kent say to time the cams in at 104 +104 deg but we time them 105 in 101 exh it really wakes the bike up, a set of flat slides, a full system with ram air box & filter kit, a good refresh of the bottom end but no need to go over size on the pistons, just match the weight of the pistons & conrods to the lightest one,do this by weighing the conrod & piston with rings pins etc and take the excess material off the side of the conrods, and run a total loss.
there is more you can do but then it becomes very unreliable.
hope this is of some use to you guys .
Very interesting & informative cheers bud
Dynoshaun will be wanting to have a yarn with you I reckon
Check out his newbie post
maddog82
Post by maddog82 »
hi guys, ... ok mate ill head over now :)
Welcome to the forum Luke, looks like you will fit right in here
Wallace :character-grommit:
maddog82
Post by maddog82 »
cheers mate,
Hi Luke and welcome to the forum
Damo666
Bike Make & Model: R1 07 4C8
Post by Damo666 »
Welcome in Luke looks like a well sorted early R1 you built there :clap:
maddog82
Post by maddog82 »
thanks damo, .. yh its quite well built i guess, but still is only really at the beginning of its racing life, still so much more to do on it, and more potential to unlock from it. :D
