strange blue thing.
Andraki0190
Bike Make & Model: Yamaha YZF R1
strange blue thing.
Post by Andraki0190 »
Hi everyone.
I have recently acquired my late brothers 99 R1.
I'm about to do an oil change, but I'm stumped by the oil filter.
The filter seems to be sitting on an anodized blue spacer about 15 mm thick & not directly onto the block.
It's not one of those sandwich plate adapter's things as there's no pipes or anything going into it.
It's just a spacer which has brought the filter to within less than 8 mm of the exhaust & I ain't sure if there's enough room to remove the filter without removing exhaust.
I have a pic but don't know how to upload anything at the mo..
Has anyone got any clue as to what it is????
DobermanGuy
Bike Make & Model: 2015 YZF-R1 2CR
Re: strange blue thing.
Post by DobermanGuy »
I'm clueless but can help you with a pic upload.
1. Just create a photobucket or an Imgur account.
2. Upload photo from your phone or camera to that. Copy and paste the generated [IMG] link to the message you created.
I'm just unfamiliar with the problem but I bet one of these older cooters here can help ya. Welcome to the forum btw!!!!
2006 R6 (sold) - LeoVince fullTi exhasut, PC3 w/ custom tune
2015 R1 (active) Graves decat exh. w/ Woolich Racing Autotuner
Or use the tapa talk app on your to upload photos ,easy as
Andraki0190
http://imgur.com/CrbnIi7" onclick="window.open(this.href);return false;
Well that is it..
Welcome to the forum mate, sorry can't help with the issue tho ;)
Hi, welcome to the forum.
Steve
blake7
Bike Make & Model: R1 14B & ZX636
Post by blake7 »
It must be a type of oil cooler or an adapter to accept a non standard filter.
Andraki0190
blake7 wrote:It must be a type of oil cooler or an adapter to accept a non standard filter.
I can't imagine it being a non standard oil filter adapter. Would be easier to buy the right filter.
The oil cooler thing sound plausible, but if there were such a thing that looked like my one, Google would have found an image of it by now!
Welcome to the forum and good luck in finding out what the spacer is and removing the filter
Welcome in Andrew
There's a few things a you need to know about the 4xv , I've never seen the anodized bit your on about but if I remember I'll take a pic of mine for you tonight . The standard oil filter part number 303 so if you buy a K&n it's KN 303 or High Flow is HF 303
Andraki0190
jompy wrote:Welcome in Andrew
I have a genuine Yamaha filter to go back on.
I'm waiting for a drain bolt washer to arrive before I actually find out what this thing is.
And remember NOT to tighten the sump bolt up to 42nm as stated in the manuals , it's closer to 20nm
Here's a link to a 4xv oil cooler...
http://www.ebay.co.uk/itm/YAMAHA-YZF-R1 ... SwKrhVZefw" onclick="window.open(this.href);return false;
Obviously there should be two coolant lines connected to it, so if not, is there a couple of blanked off hoses you can see anywhere?
Has someone plumbed in a oil cooler radiator instead maybe?
Edit, just been looking at some images and it appears the oil cooler sits next to the oil filter bolted to the block. :think:
It looks like an adapter for an oil cooler. What's on the other end of the hose?
Sent from somewhere using Tapatalk
Andraki0190
petepassion wrote:Here's a link to a 4xv oil cooler...
Oil cooler is present & connected with the appropriate pipes.
You can just see it in the pic.
http://imgur.com/O49NNVz" onclick="window.open(this.href);return false;
Andraki0190
Moise wrote:It looks like an adapter for an oil cooler. What's on the other end of the hose?
The hose in that pic is just a breather hose & nothing to do with it.
I just mentioned to petepassion that the oil cooler is next to the filter as it should be.
No this thing has no pipes or blanked off bits on it.
It just seems like a stupid spacer which may prevent replacing the filter without exhaust removal.
Here's the engine in my bike & my spare ( both 5jj but more or less the same as 4xv )ImageImage
As opposed to where your oil filter screws on
Heres a link to the exhaust gaskets i use http://www.ebay.co.uk/itm/Yamaha-YZF-R1 ... Sw7ThUeF-H
If you want your pictures to be visible on the forum so that people don't have to click on the links then heres 3 ways to post pics
""get yourself a free photobucket account & follow the idiots guide to posting pics from your pc
posting.php?mode=reply&f=6&t=10659
if you don't want to open a photobucket account then an alternative is go to
http://tinypic.com/
1 - "choose file" and browse to the image you wish to upload from your PC
2 - In the "resize" drop down choose either 15" or 17" screen (15 is enough and fast too)
3 - Press "upload now" where it will ask you to type in a couple of words to confirm you are a human being and not an automated program.
4 - Once done copy the text from the "IMG Code for Forums & Message Boards" field
5 - Then just paste it exactly as is in to your message.
or you can post direct from your not so smart phone using tapawank (tapatalk) it's great for posting pic's & notifications but wank for viewing the forum ;)
Ahh you've already posted this on the yank forum ;)
http://www.r1-forum.com/forums/101-98-9 ... pacer.html
Andraki0190
jompy wrote:Ahh you've already posted this on the yank forum ;)
Yeah I just picked the first two R1 forums & went for it.
I didn't realize it was American.
It ain't helped yet though as no one knows what it is.
I think I put 98 R1 on the other one. Well it was made in 98, registered 99.
yeah some of our guys use that forum for info if they can't find it here , theres some very knowledgeable people on there if you can put up with the massive amount of dick heads
I reckon that's a magnet to pick up any metallic foreign objects in your oil
Sure I've seen them for sale elsewhere before
Welcome in btw
Andraki0190
2002r1jon wrote:I reckon that's a magnet to pick up any metallic foreign objects in your oil
I reckon your right.
But I'm pretty good at looking for stuff on the web & I couldn't believe I found zero reference to anything that looked like the thing that's on me bike.
I don't know how far the filter unscrews before it comes away from the thread, but I ain't got much room between it & the exhaust.
What a total ballache and what a total waste of time if it is them magnet type things, id try an old fashioned chain wrench on that and turn the filter off , if the filter moves then get that thing off and chuck it in ra bin,if its trapped by exhaust then you've no choice then but tae drop the exhaust off, I'm fraid its one of em jobs , you gotta suck it and see, cant say ive ever seen anything like that before though, good luck!!
I couldn't find anything either. You'll probably find out what it's for when you take the filter off. It doesn't unscrew very far before you can remove it.
