Bike not running correctly.
R1 Phil
Bike Make & Model: 2004 R1
Post by R1 Phil »
Hi, I have an 2004 R1 with only 13.000 miles. Anyway having owned this bike for 12 years It now seems I have a problem with the motor going on to 3 cylinders when idling..but clears when warmed up.
Thanks in advance.
Re: Bike not running correctly.
R1 Phil wrote: Sun Nov 08, 2020 4:06 pm Hi, I have an 2004 R1 with only 13.000 miles. Anyway having owned this bike for 12 years It now seems I have a problem with the motor going on to 3 cylinders when idling..but clears when warmed up.
Thanks in advance.
Welcome in Phil
could be a number of things from HT lead braking down or coil pack ( i believe the 5v y has one on each plug ) to wiring
Hope someone can shed more light for you 👍
R1 Phil
Post by R1 Phil »
Cheers ..I've had the TPS done,.a Powercommander has been fitted the last 10 years...........only a minor issue should solve it easily .
Might be a spark plug .
R1 Phil
Post by R1 Phil »
Yeah, I'm changing plugs anyway..cheers.
Have you done a throttle body sync? If its clears when hot? Are you losing any coolant? Have you tried some millers fuel treatment? Do you have a power commander fitted?
Sent from my SM-G903F using Tapatalk
R1 Phil
Post by R1 Phil »
No throttle body sync - Haven't tried.millers .fuel treatment, yes I have PC111.
One tooth down front sprocket, K,& N,.decat Y piece ,-. And custom.map..very fast bike..mental top end..the first slight problem I've had with it..Cheers for replies chaps...
R1 Phil wrote:No throttle body sync - Haven't tried.millers .fuel treatment, yes I have PC111.
Okay get some millers but disconct the power commander and see how it runs. If ok then millers an throttle body sync. Good luck let us me know how you get on.
R1 Phil
Post by R1 Phil »
Ok cheers
r1Mike
It’s my birthday
Post by r1Mike »
Check plugs then leads.
When mine did this new plugs fixed it
R1 Phil
Post by R1 Phil »
New plugs going in. Asap
